  New Posts New Posts RSS Feed - Nissan Primera p12 odb port location
egor110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote egor110 Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera p12 odb port location
    Posted: 02 Oct 2017 at 7:35pm
Where's the odb port on a p12 ?
I've poked around down by the fuse box and can't seem to find anything
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 8:13pm
I take it it is a right hand drive car. While sat in the drivers seat just reach down by your left knee
Post Options Post Options   Thanks (0) Thanks(0)   Quote egor110 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 8:34pm
Thank you , the quest continues tomorrow.
Do i have to remove a panel or is it just the socket there ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote roy.2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 9:05pm
 No panel to remove, just run your hand along the bottom of the trim and you will find the gap.  Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote egor110 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 12:54pm
Thanks for your help , i've found it !
Got a p0113 and a p0102 code which i thinks all maf sensor related .
Monday i unplugged the maf to see if the car ran any different ( previously it was loosing power uphills) so that kind of ties in with why it's thrown the codes.
What sort of tool do i need to undo the maf ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 6:42pm
To remove the whole MAF just a normal Screw Driver or Socket
To remove the Sensor (at the top) usually a T20 Security Torx Driver.
