  New Posts New Posts RSS Feed - Nissan Primera P12 oil pan/sump
Bohica View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bohica Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 oil pan/sump
    Posted: 14 Aug 2019 at 10:21am
Hi Guys, the place that does my MOT gave me an unofficial "issue" on my last MOT.
They said my sump was badly corroded and although it was not a MOT failure, the corrosion
is so extensive that should a stone fly up from the road it will in all probability punch a hole
straight through the sump.
My question is this, I have been looking online for a new sump/oil pan and have found loads all different
prices but most worryingly all slightly different shapes even though they all come up as compatible
with my engine.
I don't want to buy one, drain the oil, remove the sump and then after destroying the gasket taking the old one off, yes I know I can't reuse the gasket but don't want to buy 2 gaskets just in case I find the new sump wont fit and I have to put the old sump back on the car.
Any advice as to how I can find the one that is actually for my engine and get this repair done just leaving me with the headlights (foxed but passed the MOT) and front discs/pads to do on the car.
Many thanks,
Paul K
I think therefor I am.
bavs83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bavs83 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2019 at 3:25pm
I would guess the best way would be to jack the car up and have a look and take some measurements. Especially when you say there are different ones available for the same engine.
That's what I would do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote roy.2 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2019 at 3:31pm
Take a picture on your phone Paul, then you can compare with the sumps you are looking at. Thumbs Up
Ant-Dat View Drop Down
NPOC Legend
NPOC Legend
1998 Primera GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ant-Dat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2019 at 5:06pm
If it's a 2.2dci Nissan list 3 and each more expensive (if you can find one) than the next. I repaired one of someone on here that couldn't actually find a replacement to fit their car.
