  New Posts New Posts RSS Feed - Nissan Primera P12 Problem Opening Boot
ETIHAD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ETIHAD Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 Problem Opening Boot
    Posted: 24 Apr 2018 at 10:59am
Hi I find it hard to lift my boot on a Nissan Primera Hatchback P12.
Could it be the boot struts need replacing.
Stevie-Boy View Drop Down
Moderator Group
Moderator Group
Legend Elite
Post Options Post Options   Thanks (1) Thanks(1)   Quote Stevie-Boy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 12:05pm
Hi, welcome to the forum Thumbs Up
So the boot opens every time, it's just hard to lift?
I would disconnect one end of each strut and just see whether the lifting is a little smoother, just to see if the struts might have seized up and be working against you. If this gets easier, you know you would need new struts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ETIHAD Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 12:55pm
CHEERS I WILL TRY THAT , THANK YOU
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 8:12pm
If the struts are not seized in any way, does the tailgate stay in the open position, or does it need t be held, does it crash shut?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ETIHAD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 5:24pm
Hi
 i have tried suggestions and the struts are not seized at all.When i open the tailgate,i have to manually
lift it up.where i think it should rise up on its own by the gas,hydraulics of the struts ?.it has never opened properly since i bought the car . also i can stop it half way and it will just stay there not crash shut.regards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 5:35pm
Sounds normal to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote ETIHAD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 5:48pm
thank you. its the first nissan p12 i have owned and the heaviest tail gate to lift.once again thank you.
