Nissan Primera P12 Radio/Heating LCD Display help |
Post Reply | Page <1234> |
Author | ||
you will have to remove the dash I think
you could also download the free electronic service manual for your car found in the how to section
Bakerman
NPOC Member Joined: 13 Aug 2010 Location: Belgium Online Status: Points: 110 |
Mine is also 2002 1.8 Visia. When I have the lights on before it's dark outside the display is dimmed (so poor). I have to push the MOD button(with the lights on) then the right double arrow on the joypad. Then the display sets like driving without the lights on and is much more lit. I hope this helps. |
philmc1972
NPOC Guest Joined: 18 May 2011 Location: IRELAND Online Status: Points: 13 |
its looking like the dash will have to come off alright and me a total novice, arrgghh :( have u a link to the how to section? cheers :) |
philmc1972
thanks bakerman
i'll not be able to test this until the morning, but you've given me hope fingers crossed!! i'll keep use all posted p |
philmc1972
Hi Bakerman Tried the above, no luck - didn't work |
veedo
NPOC Guest Joined: 08 Jan 2013 Location: United Kingdom Online Status: Points: 1 |
hello, any luck with this hidden menu in your model without navi? i need to change mpg to litres per km and i dont now how...
v3
hamst0r
NPOC Guest Joined: 20 Jan 2013 Location: Netherlands Online Status: Points: 1 |
We have the same type of onboard computer on our older Dutch p12. For me as well i can hit the 'mod' button and then arrow to the right to change brightness from day/night mode. If that does not work i would indeed expect it to be a defective bulb. While im asking. Do you also have (beeping) parking sensors on your nissan. Most versions appear to have a reversing camera which our older onboard computer obviously does not support. I am trying to determine if our parking sensors are factory fitted or aftermarket. |
Cribber
NPOC Guest Joined: 18 Apr 2016 Location: Ipswich Online Status: Points: 3 |
Hi guys. Was there a conclusion to this issue. I have the same issue with the same console (no joystick) and was looking for a resolution as I've put up with it for about a year now as I didn't think it was repairable
marko_compa
NPOC Guest Joined: 24 Apr 2016 Online Status: Points: 2 |
Hello Guys,
I have a problem with my LCD Display on Primera P12 2.0 140HP. Today Backlight stopped working (it is very dimm). I have found a replacement unit and I wonder if this is only a display (http://www.ebay.co.uk/itm/Nissan-Primera-P12-2000-2006-Screen-Display-Unit-Monitor-28090AV612-CC5W-3002P-/252540256103) or module for everything else (radio,...). Do I need to enter a security code if I change Display. Then I would rather change only backlight or LCD unit. Thank you for your help. |
