Nissan Primera P12 rear brake / indicator lights |
Post Reply | Page <12345> |
aamier
NPOC Guest Joined: 22 Jul 2012 Online Status: Points: 260 |
hi timeshock
it has the 4 orange dials so i persume thats the 2nd edition which has the new looms? |
aamier
thanks Electrolyte
i would of thought something like that would of been spotted in 4 years of ownership to be honest. |
essNchill
It only gets spotted when it doesn't work
aamier
surely something as serious as that would be picked up when driving the car 10k miles since ownership!
but yep like many owners out there it may not get picked up. any tips on picking it up when test driving it? |
As Shaun states only when it goes wrong does it get spotted. Often it is a blown bulb and replacement which affects things, sometimes just corrosion
aamier
hi
many thanks and i'll do my best to spot it :) |
Olin
NPOC Guest Joined: 06 Oct 2013 Location: Dublin Online Status: Points: 1 |
Tried the earth fix on my 2008 primera se 1.8 hatchback and it worked a treat for me
Many thanks to the member that suggested that fix.... |
absniper66
NPOC Guest Joined: 31 May 2014 Online Status: Points: 46 |
Can I assume the earthing problem can also make the Rear fog light flicker when I apply the brakes on my Nissan Primera P12 2003. Some have suggested dirty contacts on the connector on the light assembly or the wiring harness which can be replaced via Nissan for around £40.
It doesn't do it all the time but is a little distracting when it happens.
The fix is so simple and cheap it is best to start there, you can inspect the contacts and track at the same time
absniper66
OK thanks, I will have a look, fingers crossed. I can take it that Is the flickering rear fog light on the dash console is a known symptom from this fault then .
