Nissan Primera P12 rear brake / indicator lights |
Post Reply | Page <1 345 |
turbodiesel
NPOC Guest Joined: 03 Aug 2011 Location: Dublin Online Status: Points: 62 |
I've had the same problems as many (Switch on the indicator and every light on the R/H rear cluster lights up dimmly once the brake is depressed and the indicator flashing speed doubles. When using the cruise control on the motorway and changing lanes the EMU/ECU thinks the brakes are being applied because the light cluster is lying to the brain and cancels the cruise control. I also had something like the car going into limp mode on the motorway resulting in the car being able to cruise at 100 kmh but not able to accelerate until I switched the engine on and off and then all was well power wise) all is the last week. Last night I ran an extra earth to R/H cluster and all appears well. Thanks again NPOC!
Before you do it, ask yourself, now what would a wise man do......
gazandsue58
NPOC Guest Joined: 09 Feb 2013 Location: Staffordshire Online Status: Points: 1668 |
Just love it when people tell us when we get faults right.
absniper66
NPOC Guest Joined: 31 May 2014 Online Status: Points: 46 |
Many thanks to everyone, extra earth lead fitted, problems gone away.
gazandsue58
Another earth fault fixed.
Sut
NPOC Guest Joined: 20 Jun 2016 Online Status: Points: 27 |
Thank you, another earth problem fixed.
Referee1
NPOC Guest Joined: 08 May 2017 Location: ESSEX Online Status: Points: 1 |
Hi I seem to have the same problem
The car judders or seems like its missing especially when vehicle gets warm could the rear lights fault be the problem or something else Thanks REFEREE1
MINTY
Hi and welcome to the forum
You have not mentioned your model, age or spec, petrol/diesel?
Does this happen when you are indicating?
Have you checked for any blown bulbs?
Have you recently made a bulb replacement?
Any engine management light on?
