  New Posts New Posts RSS Feed - Nissan Primera P12 Xenon light problem
toensberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toensberg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2018 at 5:37pm
Hi, I just posted my problems to this list. I have exactly the opposit problem;
Daytime, both HID lights is on.
Nighttime, left one lights, right one goes off.
I found one relay in the relaybox which works with the left light.
I have mixed all those similar relays and they all works with the left light, so they are probably ok.
Are there a spesific relay also for the right HID light ?
Terje
Norway
petterg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote petterg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 8:32pm
On page LT28 you'll find that in night-mode, RH low beam and LH low beam go via individual relays and individual fuses. On page LT32 it looks like thees are labled 36 (RH fuse), 37 (LH fuse), E14 (LH relay), E20 (RH relay). Fuses are 15A on diesel engine models, 20A on petrol models.
If relay and fuses are ok, the next place to look is the high/low beam switch.
From your name, it looks like we're neighbors. Bor ved Husvikveien.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toensberg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 10:35pm
Hi Petter
Thanks for your comments.
I have seen those pages, in fact I have all this printed out on paper.
Those 2 fuses for low beam are marked on the top on the fuse box, but I cannot find any markings for the relay box. All relays seems to be okey though, and I have located the relay for the right low beam, but where/which is the relay for the right low beam ? (There is no clicking sound from any other relays, so there is obviously no signals)
As you suggest the problem may be in the high/low switch when in night position....?
(My front foglights will not come on either, fuse and bulbs are ok, so the switch may have other issues too)
You are right, we are as good as neighbors.
Maybe we could have a chat and share these things ?
Jeg bor i Gamle Kongevei 26, 3170 Sem.Smile
Terje Stendal
92418407
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2018 at 6:27am
Have a look at page PG-93 for a diagram of the fusible link box and more
carmona View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carmona Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 8:49am
hello
the post is relevant.
Im looking for the "day light control unit"
and all I have funde is relay-25230-9f905snd Im not sure its the unit.
I hope for help.
add some pic'
p12 2007 2.0
carmi
damn...
Post Options Post Options   Thanks (1) Thanks(1)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 8:51am
http://www.npoc.co.uk/forum/howto-post-pictures-using-imgur_topic74431.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote carmona Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 8:59am
[QUOTE=carmona] hello
I hope for help.
add some pic'
CARMI
p12 2007 2.0
damn...
Post Options Post Options   Thanks (1) Thanks(1)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 9:01am
DAYTIME LIGHT OPERATION
When the engine running, the lighting switch in the OFF position, power is supplied
l from alternator terminal 3
l to daytime light control unit terminal 8, and
l from daytime light control unit terminal 2
l through daytime light control unit terminal 5
l to terminal of LH headlamp
l from daytime light control unit terminal 3,
l through daytime light control unit terminal 4
l to terminal of RH headlamp, and
l from daytime light control unit terminal 1
l through daytime light control unit terminal 10
Ground is supplied to terminal 2 of each headlamp through body grounds E10 and E58.
I'm not sure where it is located but looking at the wiring diagram Page LT20 in the ESM it will have  a 2No 6 wire  connectors and two earths to it
Post Options Post Options   Thanks (0) Thanks(0)   Quote carmona Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 9:17am
thanks for the reply.
i was striping down the driver interior and cold not fund any unit as the diagram in ESM but my model is whit no xenon lights. it's the "conventional type".
i have realy no idea where to look for.
my front day light not working and the tail light. also the consoul not shift to night mode while i'm cminge the lights to on...
damn...
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 11:01am
is yours a north European model or Japanese import? Have you checked your fuses? Nos 32, 42 41 10 21
