Nissan Primera WP12 2.2DCi Fuel Priming |
campbell1987
NPOC Guest Joined: 01 Feb 2014 Location: Ireland Online Status: Points: 217 |
Posted: 20 Apr 2018 at 6:24pm |
Hi, I recently pulled my yd22 engine out to change the timing chain, I think all has gone well by the sounds of it cranking but i can not get it to fire up due to no fuel, My problem is i didnt plug the pipe when i removed it to stop fuel draining back.....
Can some one tell me is there a way to get the diesel back up to the engine without specialist tools...... I tried sucking the hose from the tank but that just made me turn blue and near pass out..... Any easier ways...lol
use the priming pump under the fuel filter
campbell1987
I got it..... its on top of the filter.... and i got it by sucking and pumping together......Neither on its own would do it, did not taste nice but hey.... I just fixed a fookin timing chain and it works..... Delighted... :-)
roy.2
You plonker Chris. But well done on the fix.
