P12 2005 Engine Warning Light On |
IOLAIOLA
NPOC Guest Joined: 12 Oct 2018 Location: OLD COLWYN Online Status: Points: 2 |
Posted: 12 Oct 2018 at 11:48am |
I HAVE A NISSAN PRIMERA P12 1.8 AUTO 2005 THE YELLOW ENGINE WARNING LIGHT HAS COME ON,AND THE ENGINE IS RUNNING ROUGH .LIKE A MOTOR BOAT .ANY IDEAS ?
imckay
Welcome to NPOC,
Try to read the Error Code It maybe the Timing Chain. I think you will get a Cam or Crank position error Or could be a Coil Pack. This will normally give a misfire error |
IOLAIOLA
Thanks for your reply , will try your suggestions .
Vimtoman
NPOC Guest Joined: 23 Jun 2018 Online Status: Points: 3 |
Hi,I have Nissan primera 53 plate I took out spark plugs to check them put everything back,then drove about 4 miles car was jumping so I checked spark plugs again and noticed a lead came of the connection to spark plug, the problem I have is now the engine light is on the car is running perfect so why is engine light still on, could I have caused damage or does engine light just need resetting, any help be appreciated ery grateful thanks
Vimtoman
Meant to ask, will car still be OK to drive cheers
roy.2
Hi Vincent. Welcome to NPOC.
Your engine light should go out on it's own after the car has been started/stopped a few times., If not you can always reset it. Check the How To section for reset instructions. Your car will be OK to keep driving.
imckay
Welcome to NPOC As Roy says, fine to drive. It should go out on its own within a few Days, if not
