  New Posts New Posts RSS Feed - Primera p12 2006 model stereo and ac problems
Triniman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Triniman Quote  Post ReplyReply Direct Link To This Post Topic: Primera p12 2006 model stereo and ac problems
    Posted: 20 Nov 2017 at 12:58am
Hi I have a primera p12 2006 stereo works when it wants but once it’s on it works fine so does the ac but when you switch off in order to get it working again you have to remove the terminals off the battery a couple times for it to function other than that when you start the as comes on full blast and you can’t adjust anything no functions on the controls beside the rear defogger any suggestions
Post Options Post Options   Thanks (0) Thanks(0)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 11:26am
Welcome to NPOC,
Is this a European or Japanese Model?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Triniman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 2:19pm
It’s japanese
Post Options Post Options   Thanks (0) Thanks(0)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 4:50pm
This is for the Euro but I believe the Japanese is quite similar if not the same.
http://www.npoc.co.uk/forum/p12-blank-console-screen-repair_topic32396.html
A Repair Shop that can solder Laptop Boards, Phones, etc should be able to fix
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 6:23pm
I'm not sure if that's the issue Ian.
If your screen is blank then it is almost sure to be the case.
If this is just an Audio unit problem then it may be a faulty unit or poor earth
