Nissan Primera P12, Loss of Power, help wtd.
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=45431
Printed Date: 19 Apr 2024 at 5:04pm
Topic: Nissan Primera P12, Loss of Power, help wtd.
Posted By: andy1494
Subject: Nissan Primera P12, Loss of Power, help wtd.
Date Posted: 28 Nov 2010 at 9:41am
hi there i have a p12 nissan primera 52 reg car, what i am asking for help, over the last few weeks i have had the engine stuttering and to seams like there no power to the engine, which has cause the engine warning light to flash and sometimes it has stayed on, but it not happening all the time, i first when it stayed on to it to my local nissan dealer who put a test on saying the following.
carry out consult check, engine spluttering and eng man light on, carried out diagonstic check reveals : PO171 erased fault code and reset learn and idle, air volume customer to try the vehicle, of which i did and again that afternoon started again spke to them they told me to book it in which i did.
they replaced the plugs rechecked system for DTC No DTC in system but catalyst srt not complete could be cat fault or just not being on long run. am no expert spoken to a few friends one say it could be the cat ot the lamber section not sure what that is, not spoken with the garage but i am still getting the same problem not all the time when the engine seams to have no power can some one help me with some ideas please
Date Posted: 28 Nov 2010 at 10:49am
Ah your 2nd post we were expecting, hope you are enjoying the P12 apart from this episode of course.
It sounds like one of the the MAF's (Mass Air flow Sensors) one on the air filter housing the other on the exhaust side. With care and gentle treatment they can be cleaned and allowed to dry with carb cleaner. They are delicate so don't hold the spray to close (10 2) the aim is to allow the cleaner onto the film to do its work not blast the thing clean. You will need a security torx to get it off. If that does not work the faulty one will have to be replaced. I believe they are interchangeable. but you ought to check, they are not cheap either.
Posted By: andy1494
Date Posted: 28 Nov 2010 at 2:20pm
thanks for that will have a look at it tomorrow going to get a cat test in the morning as well as to check my windows as the broke today as well
Posted By: vince776
Date Posted: 28 Nov 2010 at 2:30pm
yes defo sounds like MAF problem, as for the windows, they don't like the ice. If they are stuck and you try to open them, there is a small clip which breaks. This can be replaced but often the cables come away at the same time so the whole motor unit may need replaced!!!
Posted By: andy1494
Date Posted: 28 Nov 2010 at 5:04pm
i no just my look at the moment will look at the maf in the morning
Posted By: andy1494
Date Posted: 01 Dec 2010 at 12:25pm
replaced the MAF yesterday seams to be going ok just need to fix my window now tks for the help and advise
Posted By: andy1494
Date Posted: 02 Dec 2010 at 7:32am
any more ideas this morning it started to stutter again again with the eng man light back on please
Date Posted: 02 Dec 2010 at 10:42am
Well There are two mafs on the p12 which believe are interchangeable, So the one you took off must be working, I assume the one you put on is working so swap the one on the exhaust side with the one you took off and see what happens
Posted By: andy1494
Date Posted: 02 Dec 2010 at 2:37pm
hi there timeshock is there a diagram as i can not see another one in the engine compartment tks
Date Posted: 02 Dec 2010 at 8:59pm
timeshock! wrote:
Well There are two mafs on the p12 which believe are interchangeable, So the one you took off must be working, I assume the one you put on is working so swap the one on the exhaust side with the one you took off and see what happens |
two mafs? you sure you don't mean O2 sensors...odd that having a maf on the exhaust side of things..
Posted By: andy1494
Date Posted: 03 Dec 2010 at 7:39am
well that timeshock has said i went back to garage yesterday afternoon, they told me it just the one slightly confused
Posted By: Ant-Dat
Date Posted: 03 Dec 2010 at 8:30am
P0171 = Fuel System Lean, Bank 1
I'd be looking at the O2 sensor (front one)
Posted By: andy1494
Date Posted: 03 Dec 2010 at 11:29am
you say front one m8 but which one as i belive there are four i think
Date Posted: 03 Dec 2010 at 12:34pm
andy1494 wrote:
you say front one m8 but which one as i belive there are four i think |
you only have two O2 (Lambda sensors) you must be thinking coilpacks where are four off...
Posted By: andy1494
Date Posted: 03 Dec 2010 at 4:51pm
will have a look in the morning probley ask my neigbour he better with this than me will let you no what happens then tks
Posted By: cmurariu
Date Posted: 23 Jan 2011 at 7:31am
Dear friends,
Just purchased my Nissan p12, 2002, 60k km, 2liter, CVT, etc...
Now I need to fix a few things:
Door lock, driver side - buzz noise when it locks. It still does the job.
I plan to open the door panel to see what is wrong. any suggestions?
The window on the driver side is completely dead...I will check to see if it the motor. Are the motors from the back door interchangeable with the front ones?
The reverse camera doesn't work. Only noise on the screen when I put it into reverse. The NAV, other on screen display, etc...work fine. I suspect is the connection. Any ideas how to check for faults?
Also, I need a user manual for the car. The controls are not very intuitive. Anybody can help?
thanks a lot
Be safe!
Date Posted: 23 Jan 2011 at 11:04am
Hi and welcome to the forum, you seem to have a few irritating little niggles in with your car.
Not sure if there is much you can do with the buzzing noise other than make sure the connections are solid, sound as if it is on the way out.
The motors are not interchangeable,, as a general note it is the regulator that goes on them and the whole mechanism needs to be changed and as I say rears are different to fronts.
Other than chasing the wiring back and may be checking you have a circuit when reverse engaged not sure there is much you can do
User manuals are hard to get hold of they sometimes appear on Ebay. We have a little help with the console in the how to section which was primarily put up to help our fellow members with Japanese cars that should help you, anything specific just post up in the genera section.
