I'm new to this forum but I am hoping someone can help me with my car trouble.
I have owned a 2004 2.2. DCi primera since 2007. It had a tendency to rev up and down slightly when idle. Eventually the slight reving up/down became noticable when driving also, and then it eventually went through a phase of cutting out when I took the car out of gear and the foot of the accelarator.
In response to this I got the air filter, fuel filter and tank cleaned out (and a new battery).
A small amount of petrol was also added to the deisel to 'clean' the pipes so to speak.
Upon changing the battery (and above) the car seemed to reset itself and was going perfectly.
One day within a couple of months of above, I had the car running with the lights on to change a flat wheel on my wife's car at dark, and it just stopped. Since then it refuses to start.
Car turns over but refuses to bit.
Attempts to prime the filter head whilst turning engine and disconnecting the return pipe and closing it with finger make her turns over better but she still fails to fire.
It would appear that there is no fuel or not enough fuel getting to the injectors to start the car.
I don't believe there is a problem with the fuel filter at this stage. It would appear to be somwehere between the fuel filter and the injectors. (It is almost as if the car was immobalised ).
To a non-mechanic like myself this would point to the injector pump, but I am very nervous about going down this route if it is not necessary (as I have heard they are key coded and can be difficult to get the car keyed up to a replacement pump).
I'd appreciate it if anyone can suggest things to check first before going down this route.
e.g. are there any filters or gauzes or relay switches on this model that could give the same symptoms?
Thanks for any help or suggestions.
