P12 Primera 2002 - Unable to find EML code meaning
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=78248
Printed Date: 17 Apr 2024 at 11:05pm
Topic: P12 Primera 2002 - Unable to find EML code meaning
Posted By: Bradders33
Subject: P12 Primera 2002 - Unable to find EML code meaning
Date Posted: 26 Feb 2017 at 2:15pm
Hi all,
I have a 2002, 1.8 P12 Primera.
EML randomly came on yesterday with onscreen warning. I've done the pedal process to get EML to flash the code.
But I can't find the code anywhere.
I'm getting 7 consistent long-ish flashes and one quick one. If it's error 71, would t it be 10 + 10 + 7 + 1? I'm confused.
I have also searched this site. But. Any seem to find what I'm looking for.
Thanks in advance.
Date Posted: 26 Feb 2017 at 2:50pm
The Code should be 4 Figures
It should flash constantly, repeating any error codes until you switch off the ignition If you had a 71 it should flash. 10,10,7,1,10,10,7,1 10,10,7,1,10,10,7,1, etc Try filming it
Or get an OBD2 Reader Handheld or Bluetooth for Android/iOS
Posted By: roy.2
Date Posted: 26 Feb 2017 at 3:09pm
Code Number Component
P0000 No Self Diagnostic Failure Indicated P0011 Intake Valve Timing Control P0021 Intake Valve Timing Control P0031 O2 Sensor Heather P0032 O2 Sensor Heather P0037 O2 Sensor Heather P0038 O2 Sensor Heather P0043 O2 Sensor Heather P0044 O2 Sensor Heather P0051 O2 Sensor Heather P0052 O2 Sensor Heather P0057 O2 Sensor Heather P0058 O2 Sensor Heather P0100 MAF (Mass Air Flow) Sensor P0101 MAF Sensor P0102 MAF Sensor P0103 MAF Sensor P0105 Absolute Pressure Sensor P0107 Absolute Pressure Sensor P0108 Absolute Pressure Sensor P0110 IAT (Intake Air Temperature) Sensor P0112 IAT Sensor P0113 IAT Sensor P0115 ECT (Engine Coolant Temperature) Sensor P0117 ECT Sensor P0118 ECT Sensor P0120 TP (Throttle Position) Sensor P0121 TP Sensor P0122 TP Sensor P0123 TP Sensor P0125 ECT Sensor P0127 Intake Air Temperature Sensor P0128 Thermostat Function P0130 Closed Loop, Bank 1 Or Front O2S, Bank 1 P0131 Front O2 Sensor, Bank 1 Lean Shift Monitoring P0132 Front O2 Sensor, Bank 1 Rich Shift Monitoring P0133 Front O2 Sensor, Bank 1 Response Monitoring P0134 Front O2 Sensor, Bank 1 High Voltage P0135 Front HO2S Heater, Bank 1 P0136 Rear O2S, Bank 1 P0137 Rear O2S, Bank 1 Minimum Voltage Monitoring P0138 Rear O2S, Bank 1 Maximum Voltage Monitoring P0139 Rear O2S, Bank 1 Response Monitoring P0140 Rear O2S, Bank 1 High Voltage P0141 Rear H02S Heater, Bank 1 P0144 O2 Sensor Heather P0150 Closed Loop, Bank 2 Or Front O2S, Bank 2 P0151 Front O2 Sensor, Bank 2 Lean Shift Monitoring P0152 Front O2 Sensor, Bank 2 Rich Shift Monitoring P0153 Front O2 Sensor, Bank 2 Response Monitoring P0154 Front O2 Sensor, Bank 2 High Voltage P0155 Front HO2S Heater, Bank 2 P0156 Rear H02S Sensor, LH Bank P0157 Rear O2S, Bank 2 P0158 Rear O2S, Bank 2 P0159 Rear O2S, Bank 2 P0160 Rear O2S, Bank 2 P0161 Rear H02S Heater, LH Bank Or Bank 2 P0171 Fuel System Lean, Bank 1 P0172 Fuel System Rich, Bank 1 P0174 Fuel System Lean, Bank 2 P0175 Fuel System Rich, Bank 2 P0180 Tank Fuel Temp Sensor P0182 Fuel Tank Temperature Sensor P0183 Fuel Tank Temperature Sensor P0217 Engine Coolant High Temperature Enrichment Protection P0221 Throttle Position Sensor P0222 Throttle Position Sensor P0223 Throttle Position Sensor P0226 Accelerator Pedal Position Sensor P0227 Accelerator Pedal Position Sensor P0228 Accelerator Pedal Position Sensor P0245 Supercharger Bypass Valve Control Solenoid Valve P0300 Random Misfire P0301�P0308 Misfire, Cylinder No. 1�8 P0325 Knock Sensor, Bank 1 P0327 Knock Sensor P0328 Knock Sensor P0330 Knock Sensor, Bank 2 P0335 CKP (Crank Shaft Position) Sensor P0340 CMP (Cam Shaft Position) Sensor (Phase) P0345 CMP Sensor (Phase) P0350 Ignition Signal P0400 EGR System P0402 EGRC/BPT Valve P0403 EGR Volume Control Valve Circuit P0405 EGR Temperature Sensor P0406 EGR Temperature Sensor P0420 TW (Two-Way) Catalyst System, Bank 1 P0430 TW Catalyst System, Bank 2 P0440 EVAP Small Leak P0441 EVAP Control System Purge Flow Monitor P0442 EVAP Control System P0443 Purge Control/V & S/V P0444 EVAP Canister Purge Volume Control Solenoid Valve P0445 EVAP Canister Purge Volume Control Solenoid Valve P0447 EVAP Canister Vent Control Valve P0450 EVAP Pressure Sensor P0451 EVAP System Pressure Sensor P0452 EVAP System Pressure Sensor P0453 EVAP System Pressure Sensor P0455 EVAP Control System P0456 EVAP Control System P0460 Fuel Level Sensor Unit (Slow) P0461 Fuel Level Sensor Function P0462 Fuel Level Sensor P0463 Fuel Level Sensor P0464 Fuel Level Sensor Circuit P0500 Vehicle Speed Sensor P0505 IACV/AAC Valve P0506 Idle Speed Control System P0507 Idle Speed Control System P0510 Closed TP Sensor P0550 Power Steering Pressure Sensor P0600 A/T Comm Line P0605 ECM/ECU P0650 Malfunction Indicator Lamp P0705 PNP Or Inhibitor Switch P0710 ATF Temp Sensor P0720 VSS A/T P0725 Engine Speed Signal P0731 A/T 1ST Signal P0732 A/T 2ND Signal P0733 A/T 3RD Signal P0734 A/T 4TH Signal Or TCC P0740 TCC SV Solenoid P0744 A/T TCC Signal P0745 Line Pressure S/V P0750 Shift Solenoid/V A P0755 Shift Solenoid/V B P1031 Air/Fuel Ratio Sensor Meter P1032 Air/Fuel Ratio Sensor Meter P1065 ECM Power Supply Heater P1102 Mass Air Flow Sensor Function Heater P1103 MAP Sensor Heater P1104 MAP Sensor Heater P1105 MAP/BARO Switch SOL/V P1108 MAP Sensor Heater P1110 Intake Valve Timing Control, LH Bank P1111 Intake Valve Timing Control Solenoid Valve P1119 Radiator Temperature Sensor Circuit P1120 TP Sensor 2 P1121 Electronic Throttle Control Actuator P1122 Electronic Throttle Control Actuator P1124 Throttle Control Motor Relay P1125 Tandem TP Sensor P1126 Throttle Control Motor Relay P1128 Throttle Control Motor P1130 Swirl Control Valve Control Solenoid Valve P1131 Swirl Control Solenoid Valve P1132 Swirl Control Valve P1135 Intake Valve Timing Control, RH Bank 2 P1136 Intake Valve Timing Control Solenoid Valve P1137 Swirl Control Valve Position Sensor P1138 Swirl Control Valve P1140 Intake Valve Timing Control Position Sensor, LH Bank 1 P1143 Heated O2 Sensor 1 P1144 Heated O2 Sensor 1 P1145 Intake Valve Timing Control Position Sensor, RH Bank 2 P1146 Heated O2 Sensor 2 P1147 Heated O2 Sensor 2 P1148 Closed Loop, Bank 1 P1163 Heated O2 Sensor 1 P1164 Heated O2 Sensor 1 P1165 Swirl Control Valve Control Vacuum Check Switch P1166 Heated O2 Sensor 2 P1167 Heated O2 Sensor 2 P1168 Closed Loop, Bank 2 P1169 Heated O2 Sensor 3 P1170 Heated O2 Sensor 3 P1210 Traction Control Signal Circuit P1211 ABS/TCS Control Unit P1212 ABS/TCS Communication Line P1217 Engine Coolant Temperature P1220 FPCM P1221 Throttle Actuator Circuit P1222 Temperature Sensor Circuit P1223 Throttle Position Sensor 2 P1224 Throttle Position Sensor 2 P1225 Closed Throttle Position Learning P1226 Closed Throttle Position Learning P1227 Accelerator Pedal Position Sensor 2 P1228 Accelerator Pedal Position Sensor 2 P1229 Sensor Power Supply P1271 Air/Fuel Ratio Sensor 1 P1272 Air/Fuel Ratio Sensor 1 P1273 Air/Fuel Ratio Sensor 1 P1274 Air/Fuel Ratio Sensor 1 P1276 Air/Fuel Ratio Sensor 1 P1278 Air/Fuel Ratio Sensor 1 P1279 Air/Fuel Ratio Sensor 1 P1320 Ignition Signal, Primary P1335 CKP Sensor (Ref) P1336 CKP Sensor (POS) Cog P1400 EGRC Solenoid/V P1401 EGR Temp Sensor P1402 EGR System P1440 EVAP Small Leak P1441 VC/V Bypass/V P1443 Canister Control Vacuum Check Switch P1444 Purge Volume Control/V P1445 Purge Volume Control/V P1446 Vent Control Valve P1447 EVAP Purge Flow P1448 Vent Control Valve P1456 EVAP Control System P1464 Fuel Level Sensor Circuit Ground Signal P1480 Fan Control Solenoid Valve Circuit P1490 VC/V Bypass/V P1491 VC Cut/V Bypass/V P1492 Purge Control/V S/V P1493 Purge Control/V & S/V P1564 ASCD Steering Switch P1568 ICC (Intelligent Cruise Control) P1572 ASCD (Automatic Sped Control Device) Brake Switch P1574 ASCD Vehicle Speed Sensor P1605 A/T Diag Comm Line P1610 NATS Malfunction P1611 NATS Malfunction P1612 NATS Malfunction P1613 NATS Malfunction P1614 NATS Malfunction P1615 NATS Malfunction P1705 TP Sensor A/T P1706 PNP Switch P1720 Vehicle Speed Sensor- A/T Output P1760 Overrun Clutch S/V P1775 Torque Converter Clutch Solenoid Valve P1776 Torque Converter Clutch Solenoid Valve P1780 Shift Change Signal P1800 VIAS Control Solenoid Valve P1805 Brake switch P1900 Cooling Fan P2122 Accelerator Pedal Position Sensor P2123 Accelerator Pedal Position Sensor P2127 Accelerator Pedal Position Sensor 2 P2128 Accelerator Pedal Position Sensor 2 P2135 Throttle Position Sensor P2138 Accelerator Pedal Position Sensor U1000 CAN* Comm Circuit U1010 CAN* Comm
------------- Roy
Date Posted: 26 Feb 2017 at 3:37pm
Thank you.
Here's a link to video.
https://youtu.be/AEAtD0EpXK8
Date Posted: 26 Feb 2017 at 4:02pm
Need a longer video to see what happens after the 7 Long and 1 Short
Date Posted: 26 Feb 2017 at 4:04pm
7 Short and 1 Long I mean
Date Posted: 26 Feb 2017 at 4:13pm
Date Posted: 26 Feb 2017 at 6:09pm
The guys are trying to help you read the code correctly and you are only giving a small picture, please post up the repeating flashing code from start right through the whole cycle
Date Posted: 26 Feb 2017 at 6:20pm
I can do, but what's in the video is exactly what happens. Nothing else happens before or after the flashes except for a static EML.
Date Posted: 26 Feb 2017 at 6:21pm
PS: It doesn't repeat either. It's static, I do the pedal stuff, the flashes happen as per the video. Then it's static again.
Date Posted: 26 Feb 2017 at 7:43pm
If you have no other symptom from the car indicating you have a running problem I suggest continue right through with the procedure to clear the code and see if it returns
Date Posted: 26 Feb 2017 at 7:44pm
Take two video...
https://youtu.be/ikcRNfayLYo
Date Posted: 26 Feb 2017 at 7:45pm
Thank you. It's cleared for now. Just a worry when the error comes up saying not to drive at high speeds and there being a risk of breakdown.
Posted By: Electrolyte
Date Posted: 26 Feb 2017 at 8:43pm
Now that you have cleared the code it may be worth running the test again.
With no fault codes in memory it should be 0000 ie 10 flashes + 10 +10 +10 . It will give peace of mind that the system is working.
Date Posted: 26 Feb 2017 at 8:54pm
If there is a genuine fault the light will come back on after it detects the fault a couple of times.
Date Posted: 26 Feb 2017 at 9:35pm
timeshock! wrote:
If there is a genuine fault the light will come back on after it detects the fault a couple of times. |
Thank you. I have. It's still as per the video.
Date Posted: 26 Feb 2017 at 9:43pm
And you have followed these instructions and have a p!2
http://www.npoc.co.uk/forum/p12-all-engines-read-reset-ecu-fuel-pump_topic54932.html" rel="nofollow - http://www.npoc.co.uk/forum/p12-all-engines-read-reset-ecu-fuel-pump_topic54932.html
http://www.npoc.co.uk/forum/nissan-primera-p12-engine-management-light-reset_topic54280.html" rel="nofollow - http://www.npoc.co.uk/forum/nissan-primera-p12-engine-management-light-reset_topic54280.html
http://www.npoc.co.uk/forum/which-nissan-primera-do-i-own_topic194.html" rel="nofollow - http://www.npoc.co.uk/forum/ - primera-do-i-own_topic194.html
Date Posted: 27 Feb 2017 at 9:34am
Think you may be holding the pedal down too long ? Take your foot off as soon as the MIL goes out I don't hear that happening in the video. If you hold it down too long it goes into the idle relearn mode.
Posted By: ellisjd
Date Posted: 16 Jun 2017 at 2:35pm
Yesterday my P12 stalled whilst waiting in a queue. It took a few goes to restart and afterwards it showed on screen a malfunction may have occurred and to go to a Nissan dealer. I have now removed this screen message by completing the reset function and at the same time the code was noted which is 0335. This code appears to be a crankshaft sensor. Should I continue to drive now that the message has gone or should I take it to a Nissan dealer for them to investigate. Or should I see it it reoccurs and then take it. I'm worried that it might happen at a more awkward time such as when I am on a long journey. What is the worst scenario?
Date Posted: 16 Jun 2017 at 4:12pm
What happens depends upon the actual fault. Sometimes (more often than not) it is a connector wiring wear/loose issue. Occasionally it is a faulty sensor and needs to be replaced. Should it be a genuine fault then this indicates a stretched timing chain, ignoring this could result in it snapping and destruction of the engine. It can be checked by removing the timing cover and measuring the distance of the indicator on the tensioner, I think it should be no more than 10mm. the last place I would take it is a Nissan dealer.
