Hi 2005 Primera owner
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=78946
Printed Date: 16 Apr 2024 at 4:15pm
Topic: Hi 2005 Primera owner
Posted By: steakpie
Subject: Hi 2005 Primera owner
Date Posted: 10 Aug 2017 at 6:48pm
Hi and thanks for the add....I have of a problem just bought the car and the indicators don't work.. tried all the fuses they are fine then went looking for the flasher relay...cant find it anywhere
Would anyone happen to know when its located... ive got all the plastics off under the dash on both sides
Thanks for any help you could give
Posted By: Marcuo
Date Posted: 10 Aug 2017 at 8:18pm
hi. ome cars when you pres reset button and turn key to ON the gauges enter self test so you at least will si if gauges work or its out of gauges problem
Date Posted: 11 Aug 2017 at 7:02am
Welcome to NPOC,
The Indicators are controlled by the SECU.
Service Manual http://www.npoc.co.uk/forum/nissan-primera-factory-service-manuals_topic29493.html
Look in the Electrical Chapter, BCS Section and Lighting Section
Check Fuses 10 (Top Row 2nd from Right) and 30 (Bottom Row 2nd from Right) inside the Car
The SECU is coded to the ECU.
One from another Car will need to be coded by Nissan. Don't think the Car will start if not coded.
Posted By: RS Tom-Hundred
Date Posted: 11 Aug 2017 at 9:30am
Welcome to the club Thumbs Up
Posted By: steakpie
Date Posted: 11 Aug 2017 at 2:11pm
Doesn't sound good.. checked all the fuses inside and all are ok
Posted By: Janner
Date Posted: 12 Aug 2017 at 8:46am
Welcome in :)
Date Posted: 12 Aug 2017 at 12:23pm
Have a look here
http://www.npoc.co.uk/forum/nissan-primera-p12-interior-lights-secu-diy-fix_topic44536.html" rel="nofollow - http://www.npoc.co.uk/forum/nissan-primera-p12-interior-lights-secu-diy-fix_topic44536.html
