Nissan primera p11 emission test fail.
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=78947
Printed Date: 23 Apr 2024 at 6:59pm
Topic: Nissan primera p11 emission test fail.
Posted By: primera p11 97norway
Subject: Nissan primera p11 emission test fail.
Date Posted: 11 Aug 2017 at 3:37pm
I failed the Co test measurements. My values at idle is Co 0.701. To pass the test i have to be under Co 0.50.
At fast idle my values are Co 0.632. The max values to pass are Co 0.30.
Are these values way over the max limits? becouse i have no clue on this value meassurements. The engine was hot before the test. After the test i was told that i have to change the catalysator to pass the test... or are there other ways to pass this test without having to change the catalysator with this Co values? I would be glad if someone could help me out with this test :) thanks!
All the values on the emission test:
Meassurement at idle: Lamda 0.986 Co 0.701 %vol CO2 14.84 %vol HC 166 ppm vol O2 0.31 %vol COcor 0.701 %vol
Fast idle: Lamda 0.992 Co 0.632 %vol CO2 14.84 %vol HC 124 ppm vol O2 0.36 %vol COcor 0.632 %vol
Test failed.
Date Posted: 11 Aug 2017 at 3:56pm
Also. I have changed fuel filter, sparkplugs, air filter, oil filter and oil change still the test failed.
Date Posted: 11 Aug 2017 at 5:39pm
I take it the exhaust system doesn't have any leaks since it's been test? If not then change the cat converter.
Posted By: d60_tag
Date Posted: 13 Aug 2017 at 12:55pm
primera p11 97norway wrote:
Also. I have changed fuel filter, sparkplugs, air filter, oil filter and oil change still the test failed. |
I had a Renault that was failing emissions in a similar way- me too changed all the things you mention above and although the readings improved, cleaned throttle body etc.. inspected/ cleaned other things.. However it still failed the test... This happened about 4 times and it would fail.... !!
...Finally changed the CAT and the readings became really low and the car passed very easily the tester said. Would think the CAT is probably the reason it is failing, its the first thing I would change, if all looks okay, as Primeragt says. Expect it will pass when you do that, given that it is in order otherwise. Think they just get old and wear out somewhat.
Date Posted: 14 Aug 2017 at 4:01pm
Im pretty sure that the exhaust system doesn't have any leaks :) im gonna change the cat. Im going for an iniversal cat since its a lot cheaper. Thx for helpin me out here :)
Date Posted: 14 Aug 2017 at 4:04pm
I think the old cat has done it's job for 20 years now, i think its time for retirement :D
Posted By: Totenkopf
Date Posted: 15 Aug 2017 at 7:44pm
When you're replacing the catalytic converter, post a picture of the monolith here. Catalytic converters fail more often as a result of oil consumption (overheats the converter) etc. than just age. Your fast idle readings tell me that the engine is running rich. Are all the ignition components (coil, cap, rotor, cables and spark plugs) in good condition? The lambda value should be 0,97-1,03 and the HC should be below 100. This is the case in Finland, don't know about UK or Norway.
Posted By: d60_tag
Date Posted: 15 Aug 2017 at 9:14pm
Totenkopf wrote:
...The lambda value should be 0,97-1,03 and the HC should be below 100. This is the case in Finland, don't know about UK or Norway.
Yes- is the same values here in UK.
Posted By: d60_tag
Date Posted: 15 Aug 2017 at 9:16pm
I think the old cat has done it's job for 20 years now, i think its time for retirement :D |
Yes- it has probably done very well if it has lasted that long. Mine is a 1999, not sure if mine is still original or not- think my backbox sliencer is still original!
