Nissan Primera P11 fault code P0338 wiring diagram
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=79140
Printed Date: 16 Apr 2024 at 10:18pm
Topic: Nissan Primera P11 fault code P0338 wiring diagram
Posted By: Datsun73
Subject: Nissan Primera P11 fault code P0338 wiring diagram
Date Posted: 04 Oct 2017 at 10:58am
Hi all
Hopefully I can find some help in this forum.
I have P11 144 Primera which is giving fault code "P0338 Crankshaft Position Sensor 'A' Circuit High Input"
Sensor has been changed and starter is ok and now it seems that there is something wrong with wiring. One possible cause to this fault is Wiring short to positive, CKP sensor ECM.
Does anyone faced this same kind of issue? And how to fix this, where can I find wiring diagram for this so I can possible re-wire it
Thx in advance
Date Posted: 04 Oct 2017 at 4:32pm
You most likely have the common cam chain problem.
Posted By: Datsun73
Date Posted: 04 Oct 2017 at 6:04pm
What you mean with common cam chain problem?
Date Posted: 04 Oct 2017 at 6:32pm
With the qg engines,the cam chain stretches,it's a design fault.When any codes come up relating to the crank circuit ect it only means one thing...The cam chain.
Posted By: Datsun73
Date Posted: 08 Oct 2017 at 8:58am
Thx. Should this fault come during normal drive as well if it has been reseted before? My car don't give it even I'm driving 200 miles after start. It only occures during starting the car, could it be result of poor battery or starter?
Date Posted: 08 Oct 2017 at 3:49pm
Even if you had a poor battery or a bad/failing starter motor you would not of got the fault code you have got...It's the cam chain 100%
