Nissan Primera P11 none start when hot
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=79237
Printed Date: 18 Apr 2024 at 4:29pm
Topic: Nissan Primera P11 none start when hot
Posted By: s.r.pete
Subject: Nissan Primera P11 none start when hot
Date Posted: 02 Nov 2017 at 8:56pm
Hi all, 2nd time of trying, just rejoined the club after many moons, as i've just bought a 1.6 P11 off an old chap, 1997 1.6 Precicion, only done 28,000 miles, very tidy and clean, however i have one problem she won't start when hot, you have to leave it for a good 45 mins. before she will go again, any ideas what could be the problem.
------------- pdg
Date Posted: 02 Nov 2017 at 9:02pm
Could be fuel pump/relay for it.
Had a bad one recently,would still start but cut out after a few secs when warm/hot,let it cool down and it would run for a lot longer.
Also check for spark when hot,could be a failing distributor/crank sensor which not unheard of on a ga16de engine.
Posted By: s.r.pete
Date Posted: 03 Nov 2017 at 9:21pm
ok thanks will check them out.
------------- pdg
Posted By: s.r.pete
Date Posted: 05 Nov 2017 at 9:25pm
hi again, thanks for your help, got it sorted, not so bad after all, interesting little thing, wait for it !! the little sprung loaded terminal on the inside of the Dissy cap, the one that sits on top of the rotor arm was missing, only a hole there, how i was getting a spark i don't no, guess after i managed to get it started it must have been arcing over, anyway all sorted, many thanks, starts on 1/4 of a turn now
------------- pdg
Date Posted: 05 Nov 2017 at 9:50pm
Good to hear
