If it is the pan this is taken from the ESM for your engine
CAUTION:
To avoid the danger of being scalded, never drain the engine oil when the engine is hot.
REMOVAL
1. Remove engine undercover.
2. Remove RH front wheel.
3. Remove right side splash cover.
4. Remove front drive shaft assembly RH side. Refer to FAX-11, "FRONT DRIVE SHAFT" .
5. Remove rear torque rod mounting bolt as shown.
6. Drain engine oil. Refer to LU-16, "Changing Engine Oil" .
CAUTION:
Perform when engine is cold.
MBIB0951E
1. Baffle plate 2. Gasket 3. Oil pan
4. O-ring 5. Drain plug 6. Oil level gauge (with oil filer cap)
7. Crankshaft position sensor
MBIB0952E
OIL PAN
EM-151
[F9Q]
C
D
E
F
G
H
I
J
K
L
M
A
EM
7. Remove oil pan and transaxle joint bolts.
8. Support the engine bottom of the oil pan with a transmission jack
etc.
9. Remove oil pan bolts in the reverse order as shown.
l Insert seal cutter (special service tool) between oil pan and
cylinder block. Slide tool by tapping on the side of the tool with
a hammer.
CAUTION:
Exercise care not to damage mating surface.
10. Remove oil pan.
MBIB0953E
MBIB0954E
MBIB0820E
SEM365EA
EM-152
[F9Q]
OIL PAN
11. Remove baffle plate mounting bolt, then remove baffle plate.
INSPECTION AFTER REMOVAL
Clean oil pump assembly if any object attached.
INSTALLATION
l Install in the reverse order of removal paying attention to the following.
1. Install baffle plate.
2. Apply liquid gasket as shown.
l Use Genuine Liquid Gasket or equivalent.
3. Install oil pan bolts in the numerical order as shown.
4. At least 30 minutes after oil pan is installed, pour engine oil.
INSPECTION AFTER INSTALLATION
l Inspection the engine oil level. Refer to LU-16, "ENGINE OIL" .
l Start the engine, and make sure there is no leak of engine oil. Refer to LU-16, "ENGINE OIL" .
