Alternator belt
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=80419
Printed Date: 29 Mar 2024 at 7:54am
Topic: Alternator belt
Posted By: Oliver01081985
Subject: Alternator belt
Date Posted: 10 Jan 2019 at 6:49pm
Hello iam french i need help for change alternator belt.please help me.thank you My car p11
Date Posted: 10 Jan 2019 at 9:10pm
Date Posted: 10 Jan 2019 at 9:32pm
Posted By: daskulthomas
Date Posted: 13 Jan 2019 at 10:26am
Unfortunately you cannot change the alternator belt without taking the water pump & air conditioning belts off.
Generally most belts are tensioned by the pump (air con/ power steering) at 3 places: at the base of the pump with 2 bolts (14mm) that allow them to pivot and on top there should be a nut or bolt (10 or 12mm) that pulls it outward.
Undo these and you should be able to take all belts off.
------------- _______________ CA18ET S12 GA16de+T25 K11
Posted By: RS Tom-Hundred
Date Posted: 14 Jan 2019 at 11:17am
Is that really the case about the water pump?
I could change the alternator belt (and alternator) in less than half an hour on the P10 GA16DE (had alot of practice with them failing though tbh) and there were no other belts to remove first.
I can believe the AC one is possible (my P10 didnt have AC so maybe the belt is on outer side of pulley and needs to come off?) but pretty sure I didn't have to take off a belt for water pump?
Not saying you are wrong and by all means it could be different on the P11 GA16DE but would be surprising if they had changed it.
Date Posted: 14 Jan 2019 at 11:50pm
I wasn't aware of the design differences between a P10 GA and a P11 GA. However, above is the engine in my micra and I'm not sure how I'd fiddle the alternator belt off without removing the other two.
Date Posted: 15 Jan 2019 at 2:31pm
Ah now it's all coming back to me! Yep, you are exactly right, sorry!
I didn't have all the AC gubbins up front so that was no issue for me but I think I must have taken the water pump belt off when I did the alternator belt (and replaced both belts at the same time).
I was confusing this with swapping alternators in under 30 mins, whereby I would keep the same belt on (because I had already replaced it [as above]!)
Apologies for the confusion - this was about 12 years ago and my memory failed me!
