  New Posts New Posts RSS Feed - Reverse camera comes on when i press the brake ped
deejo7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deejo7 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 8:48pm
This helped me so much THANK YOU GUYS, my car started doing really crazy stuff (plus the cruise control issue when lights or turn signals are on). I thought the issue is inly on the back left side but it resolved iy half of the issues so i did the other.
Only one thing remains, when i steer hard right ir left when lights are on, the radio goes heywire, volume up or down, next song/radio station. If anyone can savd my life i’d appreciate it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 8:58pm
Your final fault has to do with the spiral wiring loom on the steering column, the loom can only be obtained from the dealer unfortunately. you can mask the fault with the last function you used as this is the one it affects, so hit the info button and that will cycle when the wheel is turned. There are a few threads on here about that issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote deejo7 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 9:10pm
Thanks!! Ill check its price if its over 70-80 Euro ill stick to your trick and go on with my life lol. If the INFO trick works I WILL LOVE YOU FOREVER :D thanks for the quick reply bro
