Nissan Primera P12 - Earth Fix Crazy |
Post Reply | Page 12> |
mrwinkey
NPOC Guest Joined: 26 Jun 2013 Location: Bradford WYorks Online Status: Points: 225 |
Posted: 01 Mar 2015 at 10:26pm |
Hi Guys,
I've been having a few issues lately that seem earth related, so I did the fix today. Now I'm sure a lot of you are going to say I'm crazy, and it's all in my head, but my car is so different. She no longer have a throttle delay. She feels to have much more power She warms up quicker She runs smoother, no more lumpy idling Her stereo sounds richer and has MUCH more bass I had to break hard today, and actually felt her ABS come on, which I haven't in a long time. She just feels much better to drive full stop. I know it all sounds crazy. Jay |
Pleased it is working for you...now....just why did you wait so long
Tran$porter
NPOC Elite Member Joined: 17 Feb 2009 Location: Manchester Online Status: Points: 199 |
Which earth cables did you fix?
"All men die! Some never live" - '54 P12 |
redshark1
NPOC Guest Joined: 31 Mar 2007 Location: Yorkshire (West) Online Status: Points: 1826 |
99% of P12 problems seem to be corrected by the earth fix!
See my Nissan Primera P11-144 common faults and fixes guide:
goodjob
NPOC Guest Joined: 28 Dec 2009 Online Status: Points: 21 |
What is the earth fix?
have a look here
http://www.npoc.co.uk/forum/p12-rear-light-removal-now-with-simple-earth-fix_topic16533.html Usually applied to version 1 P12 (pre 04 and including) to resolve electrical issues and some power loss issues particularly while indicatiing |
Jonno
NPOC Guest Joined: 20 Jun 2012 Online Status: Points: 5 |
Hi
I am unable to do this myself. Does anyone know of a garage in Surrey/Sussex who would do this fix for a realistic fee- as opposed to the £100 diagnostic, plus the rest if I take it to a main dealer? I've paid main dealers enough already for electrics problems. ( Primera P12 S : Auto: 54 reg. Thank you. |
goodjob
I live in Bracknell - anyone recommended in Bracknell and surrounding areas that could check the earth and apply the fix?
Stoatwblr
NPOC Guest Joined: 21 Oct 2009 Online Status: Points: 33 |
Thanks(1)
Running an extra earth lead is effective in the short-medium term but a bit of a bodge overall and can promote body rust where the star washer bites into the metalwork. I fixed my earthing problems about 7 years ago (after the second time the stealership had applied the "clean the connector" recall and the lamps started playing up again) The steps are much the same as in the link above up to the disassembly point. When you get the plug out, clean the crud off the earth pin in the loom socket and temporarily reassmble to make sure it's working. Be gentle when cleaning as the socket pins are fragile and easily bent out of shape. When you reassemble: This is the part that matters - the reason the connector fails is water intrusion. Fill the entire connector body, including the individual socket pins and the plugside up with vaseline or other petrolatum compound and stick it back together. If you've done it right there will be lots of vaseline oozing out as you assemble it (this will force the stuff into every crevice inside the plug) Problem solved - and 7 years later it's stayed solved. DO NOT UNDER ANY CIRCUMSTANCES USE SILICON GREASE IN ELECTRICAL CONNECTIONS. This _WILL_ result in intermittent electrical faults a few years later. Why this works: petrolatum is a low pressure grease - this means the plug and socket pins will push it out of the way to make a secure electrical connection, but the vaseline fills all internal voids and that prevents any more water getting in as far as the connector pins. It's viscous enough and the plugs are sealed enough that even at high summer temperatures it won't leak out. As far as I can tell the original problem was that the connection would "breathe" during temperature cycling (hot summer weather/cold winter weather causing air to expand-contract inside), resulting in some water eventually being drawn into the assembly despite the nominal sealing it has with the o-rings, etc. Just about all cars now use gel-filled plugs/sockets for this reason. Telcos have been using them in street-installed cable joints for 40 years too (That's where I learned about the technique). The long term problem with running an extra wire for the earth fix and not filling the assembly with vaseline is that eventually water will end up contaminating the other pins and lamps will stop working properly. Water can't cause problems if it can't get in. |
goodjob
Really interesting what you have to say but will putting the vaseline or other petrolatum compound in fix the problem without doing anything else? How does that fix the earth issue?
