  New Posts New Posts RSS Feed - Nissan Primera P12 manual transmission fluid
diesel1967 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote diesel1967 Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 manual transmission fluid
    Posted: 05 Jun 2022 at 2:02pm
changing my manual gear oil (1.8 P12), just wondered if i can use dexron III as i has about 3 litres left from a previous car ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote roy.2 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 2:16pm
Hi David. Use proper gearbox oil.   Thumbs Up
Your Dexron oil is for Automatics and I think it would not be suitable for your Manual gearbox.
Gear oil basics:
• Gear oil works to lubricate and prevent corrosion in a manual transmission.
• Because manual transmissions experience high friction during gear changes and clutch press-and-release, gear oil has additives of sulfur-bearing anti-wear compounds. This gives gear oil a distinctive, strong smell.
• Gear oil is also thicker than ATF because it serves mainly to lubricate the gearbox, transfer cases, and differentials.
Incorrectly using ATF in a manual transmission or gear oil in an automatic transmission can severely increase the wear and tear. ATF does not have the thick lubrication qualities needed in a manual gearbox, and gear oil does not contain all the additives needed to smoothly run an automatic transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote diesel1967 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 10:59pm
thanks for that roy, will use the advised oil, but after 170k im not I should touch it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote roy.2 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2022 at 12:59am
You can never change your oil too much, be it Engine or Gearbox. Thumbs Up
