Nissan Primera P12 manual transmission fluid |
Post Reply ![]() |
diesel1967 ![]() NPOC Guest ![]() Joined: 08 Dec 2013 Location: United Kingdom Online Status: ![]() Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Jun 2022 at 2:02pm |
changing my manual gear oil (1.8 P12), just wondered if i can use dexron III as i has about 3 litres left from a previous car ?
roy.2 ![]() NPOC Elite Member ![]() Joined: 23 Jan 2010 Location: Nr Bourne Lincs Online Status: ![]() Points: 3868 |
Hi David. Use proper gearbox oil.
![]() Your Dexron oil is for Automatics and I think it would not be suitable for your Manual gearbox. Gear oil basics: Incorrectly using ATF in a manual transmission or gear oil in an automatic transmission can severely increase the wear and tear. ATF does not have the thick lubrication qualities needed in a manual gearbox, and gear oil does not contain all the additives needed to smoothly run an automatic transmission. |
thanks for that roy, will use the advised oil, but after 170k im not I should touch it ?
You can never change your oil too much, be it Engine or Gearbox.
Post Reply ![]() |
