Nissan Primera P12 yellow engine light |
Moggie68
NPOC Guest Joined: 12 May 2022 Online Status: Points: 3 |
Posted: 21 May 2022 at 3:49pm |
Hi, I drive a 2005 Nissan Primera P12, an 1.8 petrol engined car retrofitted (not by me) with a 1.6 petrol engine. It has started to show yellow engine warning light, however the engine is running smoothly and the temp is normal. I have a suspect: I have been running the car with very little fuel in the tank and, scouring the internet, found that running out of fuel or leaving the fuel filling cap not properly fastened can make the ECU think that there's a problem with fuel delivery. Also, I now know that the car needs multiple error free start-stop cycles before the warning clears. Am I homing in on the right target?
Hi and welcome to the forum
The obvious thing to do is get the code read, if you don't have access to a reader you can do it manually http://www.npoc.co.uk/forum/p12-all-engines-read-reset-ecu-fuel-pump_topic54932.html when you do it
correctly just count the flashes of the light it will give a repeating sequence
of four digits, 10 flashes representing zero |
Moggie68
The code I'm getting is 0304 which is cylinder 4 misfire. Possible causes to that code are very familiar . I cleared the error code and the light stays off. If it lights up again, I'll investigate further. MOG
Moggie68
I was wrong. Again. My P12 flunked the inspection with 0355 (faulty crankshaft position sensor). I had it replaced. Result: stalling gone, improved engine running and a slight improvement in throttle response.
