Nissan P12 2005 2.2 DCi - Desperate for help!!!! |
Page <1 3456> |
rsxxx69
Points: 24 |
Posted: 28 Feb 2011 at 9:20pm |
I agree with your message: "I feel a bit bad for having sat on that golden nugget for a while now (been subscribed to that topic on navara forums for a while), but to be honest this was the first time it seemed very relevant. Agreed re the hot to and acknowledging Nissan Navara.net" If I knew that before, then I won't spend a lot of money on changing fuel pump and svc |
Points: 14483 |
Posted: 28 Feb 2011 at 9:32pm |
Well we will see, it is interesting that Sufi is having similar problems and has not changed the pump/SVC, time will tell.
rsxxx69
Points: 24 |
Posted: 28 Feb 2011 at 9:37pm |
Then if Sufi will be ok with the car then it will mean that maybe I just wasted £... But from another side it's still good that car works, and that's the good thing! |
Points: 14483 |
Posted: 28 Feb 2011 at 9:40pm |
Early days, questions....
What cause the electronic glitch
Pump/SVC Fault or other
rsxxx69
Points: 24 |
Posted: 28 Feb 2011 at 10:25pm |
It could be, or maybe not
edk_N16
Edwardo Del Dervo Joined: 04 Jun 2008 Location: Hampshire Online Status:
Points: 4555 |
Posted: 28 Feb 2011 at 11:03pm |
I just learnt that this procedure was in the car's FSM all along so I don't feel so bad now!
bytio
Points: 4 |
Posted: 04 Sep 2011 at 9:50pm |
I tried the reset as described and the car was almost undriveable very very difficult to start and wouldnt tick over below 1500rpm.
I contacted feathers diesel in Halifax and they knew the problem straight away and said it was a Suction Control Valve? anyway went there with the car they had it 2 hours, and charged £300.00 the problem was solved, no more 0089 code perfect tivk over no limp mode and better performance/fuel consumption. Well done to them.
edk_N16
Points: 4555 |
Posted: 05 Sep 2011 at 12:25am |
Yes generally it seems that if the reset does not work by itself then the SCV is to blame, which needs to be replaced and the reset done after again.
Glad it's sorted for you bytio
valilieff
Points: 1 |
Posted: 18 May 2012 at 5:57am |
Hi people,
thank you for your help i did the reset on nissan primera and it worked just fine. I saved my friend from replacing the fuel pump and scv only by resetting procedure described here thanks to the forum also for the good advice ![]() ![]()
madaboutandroid
Points: 38 |
Posted: 18 May 2012 at 5:33pm |
Tried the reset on my 2004 2.2dci today, seemed to work at first but now back to hunting when cold. New scv waiting for me at my in laws so will pick it up tonight and fit tomorrow will report back if fault cured.
Cheers Stephen
Page <1 3456> |
