Nissan Primera ABS warning light |
Hsainty76
NPOC Guest Joined: 23 Oct 2019 Location: Gosport Online Status: Points: 3 |
Posted: 23 Oct 2019 at 9:50pm |
First off, hi my name is Steve and i am a newbie, i have just brought a 2006 Primera and am very pleased with it.
My question is....I get a message saying my ABS might be faulty and i get a slight grinding noise when braking until the ABS warning light comes on and then there is no grinding noise. What could be the trouble? and how expensive could it possibly be to fix. Many thanks for reading and am eager for a response from any of you kind owners |
roy.2
NPOC Elite Member Joined: 23 Jan 2010 Location: Nr Bourne Lincs Online Status: Points: 3976 |
Hi Steve. Welcome to NPOC.
Your 1st job should be to clean the ABS rings then see what happens from there.
Hsainty76
Ok thank you for your response its much appreciated
Hi and welcome to the forum, it quite likely could be the connector under the front seats, give them a check to ensure they a=secure they often get knocked when cleaning or moving the seats
