Nissan Primera P10 high beam problem |
Eversti
NPOC Guest Joined: 21 Jul 2019 Location: Finland Online Status: Points: 2 |
Posted: 19 Sep 2019 at 4:08pm |
Hello, fellow Nissan owners. I have a problem with my passenger side high beam. It won't switch on. Other side works fine. I've ruled out the bulb and the fuse. Is there a relay somewhere or could it be a ground problem?
essNchill
Thanks(1)
I'd check the actual plastic plug that the connector (with the headlight wiring attached) plugs into. We've seen then deteriorate with heat over time (almost looks melted) or possibly look for green fuzz on the connecting pins (same block), if any signs of melting replace block, if green fuzz, you can clean the pins :)
Eversti
Yeah actually just solved it. Previous owner had done some abico repairs and the three wires of the H4 were connected wrong. So you were kind of right
schwen
NPOC Member Joined: 20 Apr 2007 Location: Spain Online Status: Points: 5225 |
Double check that if u have dual headlamps, the two main bulbs, H4 and H3 must be doing high beam.
