Nissan Primera P11 / 144 Remote installation |
Post Reply ![]() |
Author | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Klamath ![]() NPOC Guest ![]() ![]() Joined: 11 Jan 2014 Location: Westerhaar (NL) Online Status: ![]() Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Jan 2014 at 8:18am |
Hello everyone! Sorry to just drop in, only to ask a question. I'm from the Netherlands myself, and I'll have to confess I don't even drive a Nissan myself.
![]() However, a good friend of mine has a Nissan Primera from the year 2000. However he's had problems with the engine ignition system once, and due to tackling that problem, we found out its a 1999 model. (seems to have been some changes in the electronics ) Either way, I have a remote control to open the doors. wich has 2 relays. (1 for opening and closing ofcourse) wich both have a normally open and a normally closed contact. I also have 2 wires going to the indicator lights. the latter should not be a problem. However, I can't make heads or tails from the electrical wiring diagram in the Original Nissan Manual. ![]() ![]() So any help on this would be greatly appriciated. Like, where would be the best location to place the reciever module? (preferably somewhere where all the neccecairy wires would be in range to connect it to. ) If you need any more info to make a guess, I'll do my best to answer them. Regards, Tim |
It's only impossible when you stop and think about it. - Pirate Captain
essNchill ![]() Admin Group ![]() ![]() Nissyen Gaius Fluff Joined: 05 Feb 2003 Location: Hampshire Online Status: ![]() Points: 62484 |
Hi Tim and a big welcome to the forums :)
Can you please.confirm what model of Primera it is, as you're right on the changeover years... Have a look at this: http://www.npoc.co.uk/forum/which-nissan-primera-do-i-own_topic194.html It can make a difference in any help you'd receive. Many thanks and take care, Shaun |
Heya, and thanks for the welcome.
I've had a look a the link, and its safe to say that its a P11 144. (luckily its indeed really easy to recognize. ) Thanks for that link. Now I just hope there's someone who could tell me where to look. I've spend about half a day under the dashboard so far with my multimeter trying to identify the cables I'll have to use, so far no luck though. ![]() Quite frankly, I can't eem to make heads or tails of the system. Regards, Tim |
SteveB ![]() NPOC Guest ![]() ![]() Joined: 12 Mar 2007 Location: Kent Online Status: ![]() Points: 1117 |
Have you downloaded the P11-144 workshop manual? Link on this NPOC page http://www.npoc.co.uk/forum/nissan-primera-factory-service-manuals_topic29493.html
1997 2.0 SLX P11
I have, but the scematics seem incomplete about the central locking bit. :( I was hoping someone here has run into the same problem as I did.
I did check the wiring diagram, but am unable to figure out wich colors have to be shorted together to close the locks, and wich ones to open. I had hoped to find the colors of the cables that run to the switches in the lock of the drivers side door. (In my case, the left hand side. ) |
Noone ever built a aftermarket remote into their P11-144 Primera?
wickydude ![]() NPOC Guest ![]() ![]() Joined: 24 Sep 2010 Location: Netherlands Online Status: ![]() Points: 2232 |
Hi Tim, and welkom.
![]() AFAIK, Almost all primera's came with central locking and remote as standard, so there are not many who need to add it afterwards.
The original timing control box as it's called in the manual, is below the steering wheel behind the plastic panel.
It will have one of three part numbers on it:
The F905 and F914 are the ones with remote, F912 is without. If it's F905 or F914, you should only have to find some Nissan remote key fobs on ebay or such and program them to the car. Do you have a picture of the key?
feler091 ![]() NPOC Guest ![]() Joined: 04 Jun 2022 Online Status: ![]() Points: 1 |
hi io want download primeria p11 service manual
Post Reply ![]() |
