  New Posts New Posts RSS Feed - Nissan Primera P11 crank shaft position sensor
arran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arran Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P11 crank shaft position sensor
    Posted: 19 Sep 2019 at 5:37am
Hi, could someone please tell me the location of the crankshaft position sensor location on a 1997 Nissan primera gt sr20de.
Ant-Dat View Drop Down
NPOC Legend
NPOC Legend
1998 Primera GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ant-Dat Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 6:26am
Hi And welcome,
In short there isn't one.
If you having a spark issue try checking the CAS (cam angle sensor) which is inside the dizzy
Arran1980 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arran1980 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 7:34am
Cheers, Ive checked the wiring diagram and it only SHOWS a CAS.
I've replaced the dizzy, and it's fixed the issue thanks
bavs83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bavs83 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 8:22am
What was the issue you were having?
Post Options Post Options   Thanks (0) Thanks(0)   Quote arran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2019 at 9:25pm
miss firing at high rev 4000+. new plugs/leads rotor arm and cap. checked timing and fuel pressure. fuel pressure is 3 bar with ignition on engine not running 2.6 when running.
Nissan p11 144 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nissan p11 144 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 9:27am
Can i ask whats the dizzy are or stands for? I Think i have the same problem- but in a 140hp wp11
Post Options Post Options   Thanks (0) Thanks(0)   Quote essNchill Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 1:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nissan p11 144 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2020 at 1:13pm
Thank you.. unfortunatly i also already Got that part replaced.. regards from Denmark
