  New Posts New Posts RSS Feed - Nissan Primera P11 Dashboard light
Cleeeino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cleeeino Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P11 Dashboard light
    Posted: 27 Nov 2019 at 1:17pm
Hi!
I have a Nissan Primera P11 1999, but the little light on the dashboard (where the clock/date/temperature is displayed) isn't as bright as the other display (trip meter). If you look closely there is a light, but it's not bright enough to illuminate the display. Not sure if it's connected but the automatic headlights has the same issue on the left side. Headlights work fine when you turn on the actual lights via the switch. Anyone have a solution?
Thanks!
