Nissan Primera P11 Front Subframe 1.6 vs 2.0 |
SR20VEGT
NPOC Guest Joined: 25 Nov 2019 Online Status: Points: 1 |
Posted: 25 Nov 2019 at 6:15pm |
Bonjour. I've just looked at a 1.6 Primera 1998 sedan. The plan is to find a fresh shell to swap over the engine, brakes, gearbox from my P11 GT hatchback. Unfortunately it was dark and raining heavily so I didn't get the best view of the underside of the front of the 1.6. My question is this. Are the subframes different between the 1.6 and 2 litre cars? The reason I ask is while I was lying on my back in a puddle looking up at the engine area from below, it seemed to look different, specifically where the front subframe connects to the body at the back. Was I imagining a different or is it actually different? If it is different, can I use the 2.0 subframe on the 1.6 car? Are the mounting holes in the same place? Or maybe there are subframe differences between the sedan and hatchbacks?????? Any help much appreciated. I'd prefer not to get the 1.6 car and find I cant swap over the front end from the 2.0 because the mounting holes on the 1.6 shell are different! Thank you in advance!
