Nissan Primera P11 Starter motor removal |
Post Reply ![]() |
Page <123 |
d60_tag ![]() NPOC Guest ![]() Joined: 18 Jul 2015 Online Status: ![]() Points: 533 |
Yea- think on certain variants of the Primera it could be nasty job and sort of pig difficult.
Mine is a 1999 Estate 1.6 GA16DE and was not actually that bad, took about 1 hour, think other variants possibly may possibly be harder. ..... also remember to disconnect battery before changing the starter. |
FinPrimera ![]() NPOC Guest ![]() ![]() Joined: 05 Jul 2014 Location: Finland Online Status: ![]() Points: 4 |
Hi, thought I would share my experience. I got 1999 SR20DE SRi with manual gearbox and left hand drive. As mentioned before, no need to remove intake duct but removing it does not take long, it gets you more room and better view. Theres two intake support brackets, remove only that sits in timing chain side of engine or starter wont come out (and you can't loosen solenoid upper wire lead either).
- both starter mounting bolts are 14 mm and both are removed from intake duct side. - no earth leads to starter - wire looms are extremely tight fit. I got remanufactured starter by Remy and it has different angles on solenoid wires than original, have to Dremel some of that plastic guard off or wires could rip themself apart or worse, wire loom when engine vibrates. - theres room for one hand only and absolutely no extra on wiring looms even if you loosen those tie straps in engine bay(because loom goes thru firewall just where starter motor sits). |
Post Reply ![]() |
Page <123 |
