Nissan Primera P12 Hissing air intake and oil mist |
csedgbeer
NPOC Guest Joined: 11 Nov 2015 Online Status: Points: 19 |
Posted: 16 Mar 2020 at 4:14pm |
Hi Two things with my 2004 2.2dci ! There's a loud "hissing" noise from about 2.5k which is engine load dependant, i.e if you just rev the engine when stationary there's no noise, power is down a little as well sounds like it's coming from near the battery side of the engine, guess it's a split pipe somewhere but not sure when to look, have taken off the air intake/maf pipe to get a better view but can't see anything obvious also noticed there's lot of oil "mist" around that area of the engine bay (see attached) , when i took off the pipe with the MAF, on the engine side of that pipe it's a little oily inside the pipe (not the maf) so guess thats coming from the breather pipe any thoughts? , mainly on the hissing noise? Thanks Chris https://photos.app.goo.gl/MQRTd3ZwXzZcHNhe9
Sounds like you have a leak on the turbo hoses/ intercooler. if you are lucky might be a connection
