Nissan Primera P12 Stuck in Gear 1 |
Ilukena
NPOC Guest Joined: 07 May 2021 Location: Zambia Online Status: Points: 1 |
Posted: 07 May 2021 at 9:10am |
My Nissan Primera P12 is stack in Gear 1. The reverse is working well and moving forward its stack only in 1. I have done an oil change with NS1 but still no change.
Kindly help |
Estyfort
NPOC Guest Joined: 16 Nov 2017 Location: Lagos, Nigeria Online Status: Points: 116 |
Have you run a scan on the Transmission Control Module (TCM)? Perhaps
the dropping resistor's gone bad or is disconnected? Have you done any
repairs lately around the location of the crankshaft position sensor?
Hi and welcome to the forum
CVT are not that common accross here so infomation is not as prolific as oas other topics however here is a link for a start. the last post on that thread also lists your issue unfortunatley there was no reply or follow up. I would do a search on here under CVT and see what that comes up with. Is your engine management light on? |
