  New Posts New Posts RSS Feed - Nissan Primera P12 Stuck in Gear 1
Ilukena View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ilukena Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 Stuck in Gear 1
    Posted: 07 May 2021 at 9:10am
My Nissan Primera P12 is stack in Gear 1. The reverse is working well and moving forward its stack only in 1. I have done an oil change with NS1 but still no change.
Kindly help
Estyfort View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Estyfort Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2021 at 10:46pm
Kindly help
Have you run a scan on the Transmission Control Module (TCM)? Perhaps the dropping resistor's gone bad or is disconnected? Have you done any repairs lately around the location of the crankshaft position sensor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 9:01am
CVT are not that common accross here so infomation is not as prolific  as oas other topics however here is a link for a start.
the last post on that thread also lists your issue unfortunatley there was no reply or follow up.
I would do a search on here under CVT and see what that comes up with.
Is your engine management light on?
