Nissan Primera Window fallen into door panel |
Post Reply | Page 123 4> |
001mac001
NPOC Guest Joined: 27 Oct 2008 Location: Other Online Status: Points: 15 |
Posted: 25 Jun 2010 at 11:09am |
Please help, i was driving along the other day and my window just disapeared inside the door pannel , any ideas what i should do thanks
Sluffer
NPOC Legend Elite Joined: 18 May 2003 Location: Chasing jets Online Status: Points: 25342 |
Chances are the windows either fallen out of the brackets, or the brackets have come loose and cause the window to drop. If you take the door panel off, have a look at window mechanism, you will find either 2 plastic clips bolted along the top of the mechanism, the bar that runs front to back, or 2 holes where they should be, which means the brackets are still attached to the window.
If it's the former, then you need to remove glass, clean it up and the 2 brackets, and re-seat them with sealant.
If it's the latter, you need to find the 2 bolts that hold the window to the mechanism, they'll be sat in the bottom of the door.
Which model of Primera do you have, as that will help our members explain how to get the door panel off/window out etc... as therre are difference between the models.
Gazza
jayc
NPOC Guest Joined: 01 Feb 2009 Online Status: Points: 579 |
Happen to mine the other day. On removing the door card it must have happened to the previous owner who had tried bond the glass to the bracket with araldite.
I removed all the araldite and used some thick double sided tape to get a better grip on the glass.
lee85
NPOC Guest Joined: 29 May 2010 Location: sheffield Online Status: Points: 182 |
This happened to mine i tried to wind it down one morning in frost, yes stupid i know
Easy to fix as the rest explained and i am useless with cars to be honest
lpb71
NPOC Guest Joined: 04 Apr 2011 Location: Manchester Online Status: Points: 4 |
May be a silly question I know, but how do I take off the inner metal door panel.
essNchill
On what model of car?
SteveB
NPOC Guest Joined: 12 Mar 2007 Location: Kent Online Status: Points: 1117 |
My P11 driver's window fell into the door without the bracket coming loose, it was the regulator cable coming adrift from the pulley mechanism. I managed to get it all back together which was far from easy but it's been fine since last summer. Mine was caused by dirt on the window (on the part of the glass you never see) sticking the window like glue to the rubber seal (you should have seen it, toughest gunge ever created) and basically something had to give.
1997 2.0 SLX P11
lpb71
P12 - 2004
mydimons
NPOC Guest Joined: 05 Apr 2011 Location: home Online Status: Points: 1 |
mine is P11 44 drivers window dropped down seems the glass has fallen how do I get to the mechanism ? this youtube user Esurname ( search his name) has posted videos of changing his primera lock and electric mirror wiring
lpb71
Thanks, already seen that, but this P11 doesn't have the innet metal panel that the P12 does.
