Nissan Primera Window fallen into door panel |
Post Reply | Page <1234> |
essNchill
^^ I've answered this is your own thread Lee ^^
midlandfire
NPOC Guest Joined: 06 Apr 2011 Online Status: Points: 7 |
Hi
Its a common problem for window runners to fail on Primera P12s
My driverside front window also dropped down, so I whipped the door card off (some of the scews you need to unscrew are hidden in the drivers door storage) fished the window out from the bottom of the door carefully with pliers and then simply wedged the window in place. The runners holding the windows had sheered. Cant be bothered to replace!. Knowing Nisssan they would probably want a small fortune for new parts for it so...
The P12 has to be one of the worst cars ever made by Nissan.
They are just poorly built and annoying problems like this that let the car down.
Nissan please don't work with Renault again!!!
yorkie5979
NPOC Guest Joined: 07 Apr 2011 Online Status: Points: 8 |
My widow failed to go up yesterday ------ slid glass up and down while pressing button , eventually got window to stay up. Now when i press the button the window goes up and down at an angle and i have to guide it into the runners.
56 plated P12 any help would make life easier the motor seems to be running ok , its like the window has detached from mechanism.
essNchill
£50 for new pattern regs on eBay
Smileyman
NPOC Guest Joined: 21 Mar 2009 Location: Kent Online Status: Points: 63 |
This has just happened to me, I pressed the button to open the window, nothing happened, then the window slid 1/4 inch, then slid halfway open into the door - I was driving at the time! Took the car to the local dealer, they have advised new regulator and other parts required, bill is going to be not far short of £400! It's a distress spend, and distressing could have had a holiday for the same money. I need the car for work - does anyone know are there generic parts available? I don't want to go to a breakers yard in case the parts have a short life and I end up paying the labour cost twice.
Primera Dave
NPOC Guest Lights era Action! Joined: 29 Mar 2009 Location: changing Online Status: Points: 16897 |
£400!!! What to change a window regulator. These can be bought off ebay 2nd hand yes but give em so grease on em before fitted sure you be fine
Golf mk4 gti turbo. 3'' downpipe and de-cat, 2.75'' Jetex cat back, k&n induction kit and custom heat shield, 3'' intake, forge 007p dv, stage 1 190 Bhp map,Koni uprated shocks and h&r springs + more
Smileyman
Thanks for the reply
I'm going to have to work on this, I'm not sure if the car needs the whole assembly or just a section and Nissan only supply the whole assembly, also I think clips will be needed, the parts department left me a message on the mobile at lunchtime today.
Trouble is I need car on road ASAP and as a distress repair the dealer does not have any loan car available. (usually these are FOC).
imckay
Remove the door panel and wedge a length of wood under window to keep it shut until you can get it fixed.
Pattern (non-Nissan) regulator available from ebay from around £50 |
max kahn
NPOC Guest Joined: 24 Aug 2011 Location: UK Online Status: Points: 23 |
The window regulator runs up and down on a steal wire, known on the P10s to snap. If its not come off the plastic clips, the metal wire has snapped on the regultor. Also inner metal pannel use a postive drive screwdriver or a 10m socket.
diesveld
NPOC Guest Joined: 30 Jan 2012 Online Status: Points: 3 |
I had a similar problem. One runner had come loose from the window and both runners were partly broken, i.e. the plastic grip around the metal rail had broken off. The wire had not snapped, but did come loose from the runners. Nissan garage gave me a estimate of 400€.
I used the manual to get at these parts, repaired the missing grips on the runners by bolting a metal replacement on it, acting as grip. Total costs: - 1 hour work - 1,86€ for the bolts, screws and metal strips. I have pictures but cannot upload then at the moment (moderator?) I |
