Nissan Primera Window fallen into door panel |
Post Reply | Page <1234> |
posting photos |
diesveld
NPOC Guest Joined: 30 Jan 2012 Online Status: Points: 3 |
Here are the pictures of a 400€ saving operation. Btw: I did this in September 2011, so 4 months of operation now.
Assembly dismantled, wooden stick to temp. holf window in place Metal strip and 2 bolts repair runner, front view side view The cause of all problems glued back on |
ragt20
Admin Group Swiss Tony Joined: 02 May 2003 Location: Other Online Status: Points: 69654 |
top work mate...good to see, and cheers for sharing
gillic
NPOC Guest Joined: 28 Apr 2007 Location: Worcestershire Online Status: Points: 2 |
My P12 driver's side window failed this morning after I had it down to quickly wipe my door mirror. Should know better after being sub-zero overnight- as feared one of the 2 window grips had come off with the attached track runner broken off like 'diesveid' and the cables tangled around the regulator roller- when I got to the inside panel.Anyway, the FSM from the forum was a great help- albeit my 05MY is slightly different because the change on the door pull style, so had to remove the door switch pack, to access the bolt on the centre bracket before I can finally remove the door casing.
Whilst waiting for the replacement parts from flea Bay, I am hoping, if anyone can comment on the caution stated at the end of the chapter in the FSM on 'Front Dr Glass & Regulator' on page GW-76 & 77 - where a reset procedure should be carried out after parts replacement- by raising the glass to top and bottom dead centre, whilst pressing down on a 'limit switch' within the motor- should this topic is still being followed. My concern is that I can't see this switch on my 05MY motor. Am I not looking in the right place or is this no longer neccessary on post 04MY models? Window winder motor viewed in installed condition: No visible switch anywhere on motor: Thanks |
DarraghR
NPOC Guest Joined: 25 Apr 2015 Online Status: Points: 7 |
Can someone please tell me how to remove the power cable for the motor. Trying to remove clips/tacks that are holding the regulator onto the panel too |
Brianfcross
NPOC Guest Joined: 01 Aug 2020 Location: B48 Online Status: Points: 4 |
Can you tell us how to get the p12 door panel off please. The window is half up. Don’t care if it never works
imckay
Welcome to NPOC
https://www.youtube.com/watch?v=OsqhW4s4V1M&ab_channel=peugeotCitroen2CV https://www.youtube.com/watch?v=o5Em7Voh37o&ab_channel=SabriTERKENL%C4%B0
Brianfcross
Thank you
Brianfcross
Got the panel off, how does the electric window connector come off? Thanks Jackie
