Nissan Primera P12 Earth cables. Please help! |
Post Reply ![]() |
Croftylad ![]() NPOC Guest ![]() Joined: 07 Jun 2021 Location: South Wales Online Status: ![]() Points: 1 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Jul 2022 at 4:53pm |
I have a P12 2.2 wagon . It has run faultlessly for the past year, whisking me up and down the country without so much as a cough. However last week I came out of a job interview and it wouldn't start. Engine management light came on, it turned over but wouldn't start. After about 20 minutes it started up and I drove home. I used it for a couple of days then it did the same. After people mentioning earth cables I thought I'd take a look. It seems that I am missing two earth cables but I have no idea what they fasten to!
Black cable with yellow stripe. Comes from negative terminal on battery and fastens to a bolt on the chassis. The cable then carries on but the other end isn't attached to anything its hanging loose. Second earth cable is just black. One end attaches to the gearbox the other goes to the bolt on the chassis. Again this cable carries on and is also not fastened to anything. I have looked everywhere and can't see what these two earth cables should fasten to. Any help gratefully received. Many thanks Antony
timeshock! ![]() NPOC Member ![]() ![]() Joined: 29 Jan 2006 Location: Newcastle Online Status: ![]() Points: 14355 |
Hi and welcome to your first post on the forum.
![]() It sounds as if your earths are in the right place I'm not sure what the additional wire may be, however as you had an EML on I would get the code for that. http://www.npoc.co.uk/forum/p12-all-engines-read-reset-ecu-fuel-pump_topic54932.html when you do it
correctly just count the flashes of the light it will give a repeating sequence
of four digits, 10 flashes representing zero ![]() |
Post Reply ![]() |
