  New Posts New Posts RSS Feed - P12 Exhaust change & Engine Management light
Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: P12 Exhaust change & Engine Management light
    Posted: 30 Sep 2020 at 8:19pm
Hi
I’ve got a 2004 Primera which I’ve owned for the last 16 years.
The backbox was making a noise so I’ve replaced the backbox and the noise has gone.
However the car is now shaking in idle and the engine management light has turned on.
Any help would be appreciated.
Jaguar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaguar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2020 at 9:24pm
If you follow the instructions in the link and post the error code we'll tell you what it is
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 6:49pm
Yep, get that code read
