Nissan Primera P12 interior light dont work
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=44400
Printed Date: 19 Apr 2024 at 6:15am
Topic: Nissan Primera P12 interior light dont work
Posted By: tsakimak
Subject: Nissan Primera P12 interior light dont work
Date Posted: 15 Oct 2010 at 5:01pm
Hello.suddenly the interior light front and the back one stopped working,it should light when i unlock the car or open the door,if i turn it on manual it works,reading lights are working too,checked all fuses they are all ok checked the fuses in the engine all ok too.is there any relay that when i open the door gives power to the light?Does anybody know?
Posted By: tsakimak
Date Posted: 16 Oct 2010 at 9:40am
anyone that had the same problem?nobody works on nissan here?
Date Posted: 16 Oct 2010 at 9:58am
Looks like it all goes through the Smart Entrance Control Unit.
Have a look in the service manual. Electrical, Lighting, Page LT-96
Posted By: tsakimak
Date Posted: 16 Oct 2010 at 12:36pm
thanks friend i ll check that one
Date Posted: 16 Oct 2010 at 1:05pm
This has been reported by someone else recently on here not sure if we heard back what the solution was.
****edit****
Here we go
http://www.npoc.co.uk/forum/nissan-primera-p12-interior-light-fault_topic43934_post589647.html?KW=interior+light#589647 - http://www.npoc.co.uk/forum/nissan-primera-p12-interior-light-fault_topic43934_post589647.html?KW=interior+light#589647
Posted By: tsakimak
Date Posted: 16 Oct 2010 at 6:30pm
****edit****
Here we go
http://www.npoc.co.uk/forum/nissan-primera-p12-interior-light-fault_topic43934_post589647.html?KW=interior+light#589647 - http://www.npoc.co.uk/forum/nissan-primera-p12-interior-light-fault_topic43934_post589647.html?KW=interior+light#589647 |
no luck with him.I have something in mind,if i fix this i ll make it diy.
Posted By: tsakimak
Date Posted: 18 Oct 2010 at 9:58pm
So after a lot of searching finally made it. I had a problem with the interior light that didnt light when i unlocked the car,Everything seemed to be ok about fuses,relays e.t.c. A friend from here said something about probably problem of smart entrance control,so started checking it,went to nissan service and after measurements said "Yes thats the problem its the smart entrance control,changing it would cost 450 Euros" -Come again????????? i said....
After hours of googling tried something risky but yes it worked.
so...
Remove the negative pole from the baterry before you begin anything remove the plastics under the steering column to find the smart entrance control (look deep up and right)(left handed)
The smart entrance control is this
Its location under the steering column (mine is left handed)
Opened and see that this one transistor R4383 is the problem
Unsolder will be hell be prepared and have patience,all the body is solder so you have to warm very well the top to be removed first unsolder the two legs and then the body
Tried to find the same transistor r4383.......No luck at all,luckilly as we had a discussion with the seller at the electonic store he proposed this Buz 90 http://www.datasheetcatalog.com/datasheets_pdf/B/U/Z/9/BUZ90.shtml,Has the same behaviour and specifications as the r 4383 but one little problem its Bigger.
So with the help of dremel
Became like this
Be carefull while you soldering that one needs skills my friends,if you cant do it go to a electronic repair shop to do it for you
We do not solder the center leg of the transistor just cut it.Dont forget to solder the top
close it
put it back on.Everything works like a charm Interior lightning and the ring that lights to the ignition,you will notice only that when you unlock the car the signal lights flashes a bit faster.
Thanks to some russian sites for primera and nissan generally Thats all from me dudes Hope somebody will find this helpfull
P.S If the administrators wants they can make it also DIY.
Date Posted: 18 Oct 2010 at 10:11pm
cracking stuff...would be cool if you can make a DIY of this....good to see someone tackling the P12 leccy issues and fighting them head on and getting to the bottom of the problems..
Posted By: tsakimak
Date Posted: 18 Oct 2010 at 10:15pm
Posted By: tsakimak
Date Posted: 18 Oct 2010 at 11:04pm
i believe i can not make it diy myself because i am not a paid up member,so its on the hands of the moderators
Date Posted: 19 Oct 2010 at 6:20am
Excellent work
The transistor is easier to remove if you cut the 2 legs first.
Date Posted: 19 Oct 2010 at 5:13pm
Well done, i love it when someone finds out something new and is able to express it
Posted By: tsakimak
Date Posted: 19 Oct 2010 at 9:48pm
timeshock! wrote:
Well done, i love it when someone finds out something new and is able to express it |
I expressed alright my friend but i dont see any of the moderators doing this DIY,Why?
Date Posted: 19 Oct 2010 at 10:40pm
Because right now I have a mountain of work to do around here.
I will recreate your thread in our How To section, because it's excellent (well done ) - Can you please just confirm we are OK to use your photos and words with your full permission, we will off course give you full credit for the article
Many thanks and take care, Shaun
Posted By: tsakimak
Date Posted: 20 Oct 2010 at 6:20am
Many thanks and take care, Shaun |
of course my friend you have my full permission,the purpose we are here here is to share our love for our primeras and to help each other instead of going to nissan service and give them half a monthly payment for something we could fix ourselfs.by the way the transistor cost 2,5 euros,and they were looking for 450 euros
Posted By: NPOC_Tech
Date Posted: 21 Oct 2010 at 12:36am
How To is up:
http://www.npoc.co.uk/forum/nissan-primera-p12-interior-lights-secu-diy-fix_topic44536.html - http://www.npoc.co.uk/forum/nissan-primera-p12-interior-lights-secu-diy-fix_topic44536.html
Many thanks again.
Posted By: hairy
Date Posted: 03 Nov 2010 at 12:15am
Hi - I'm well impressed you worked out which the faulty component was. I've got a problem with the rear demister on my P12. Apparently this is also on the SECU board. Any advice on how I could trace the faulty component? Nissan wanted nearly £400 in the UK to replace the whole unit!
Date Posted: 03 Nov 2010 at 7:22am
There is a hole in the faulty transistor.
You would need to find which component terminal 31 (applies ground to demist relay) goes to on the board.
I would guess one of the other 2 similar looking transistors.
Posted By: Tran$porter
Date Posted: 04 Mar 2015 at 7:03am
I know this is an old topic, but i now have the interior lamps staying on permanently so I am looking at doing this fix.
Could anyone confirm that this is the correct product to use?
http://www.ebay.com/itm/1-Piece-New-FAIRCHILD-R4383-TO252-/271306415828?item=271306415828" rel="nofollow - http://www.ebay.com/itm/1-Piece-New-FAIRCHILD-R4383-TO252-/271306415828?item=271306415828
cheers
"All men die! Some never live" - '54 P12
Posted By: tsakimak
Date Posted: 04 Mar 2015 at 2:57pm
if i remember right yes this is the part,when i fixed it 4 1/2 years ago it wasnt on ebay.5 euros total and nissan wants 450 euros,way to go.Good luck my friend
Date Posted: 04 Mar 2015 at 3:28pm
I have ordered the part. £3.75 inc postage! Bargain. It is coming from America about the beginning of April, so I'll keep you all posted on the progress, thanks.
Date Posted: 22 Mar 2015 at 2:50am
UPDATE :-
Ok so the transistor arrived yestrday from America and to be really honest, IT'S TINY!!! like at first I thought they'd forgot to put it in the padded bag. So the chances of me soldering it are, at best slim. However, not to be beaten, I approached my mother in law who works for an electronics company for advice.
In minutes the new transistor was expertly soldered to the board and i rushed home to refit the SECU to the car. I'm really happy to report it worked, with no nasty side effects found as yet, needless to say i'm thrilled to pieces with the repair and the expert info supplied in these forums!
Many thanks to Tsakimak for the 'How to' it is invaluable, cheers
Posted By: fakocityab
Date Posted: 25 Jun 2020 at 5:52pm
Thanks so much, God bless you. This post really work for my nissan premiera wagon. The inner room light and the door light is always on unless i removed the control fuse that is when it will switched off. But this link resolve the problem 100%. http://www.npoc.co.uk/forum/nissan-primera-p12-interior-light-fault_topic43934_post589647.html?KW=interior+light#589647
Posted By: tsakimak
Date Posted: 26 Jun 2020 at 9:19am
thx man,glad it worked for you
Posted By: roque
Date Posted: 23 Nov 2021 at 10:45pm
fakocityab wrote:
Thanks so much, God bless you. This post really work for my nissan premiera wagon. The inner room light and the door light is always on unless i removed the control fuse that is when it will switched off. But this link resolve the problem 100%. http://www.npoc.co.uk/forum/nissan-primera-p12-interior-light-fault_topic43934_post589647.html?KW=interior+light#589647 |
Posted By: roque
Date Posted: 23 Nov 2021 at 10:46pm
Can you tell me the transístor Ref you use?
Date Posted: 24 Nov 2021 at 7:19am
BUZ90A
https://www.npoc.co.uk/forum/nissan-primera-p12-interior-lights-secu-diy-fix_topic44536.html
Posted By: roque
Date Posted: 24 Nov 2021 at 1:05pm
I Just put the buz90a, and its work
Date Posted: 24 Nov 2021 at 1:26pm
roque wrote:
I Just put the buz90a, and its work |
Excellent
