P11 tow eye
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=54325
Printed Date: 27 Mar 2026 at 5:25am
Topic: P11 tow eye
Posted By: JJ-MACKAY
Subject: P11 tow eye
Date Posted: 12 Oct 2011 at 11:54am
Hi there.
 The other day I bought a tow eye for my P11 E 1.6 hatch back, it will not fit.
I was going to use a 24mm x 25cm stainless steel bolt with an eye but it was a bit to big, then I saw the p11 ebolt and bought it.
It has the same problem as my bolt, a bit to big.
I've tried it in the front and rear.
Can any one help me.
Thank you...Confused
Wot bad weather?
Date Posted: 12 Oct 2011 at 9:47pm
Hi there and a big welcome to NPOCWave
Some of your ^^post^^ is a bit confusing.. Can I just check, do you have a P11 or a P11 144?
I'm guessing you may have a P11 144.
Enjoy the forums and take care,
Date Posted: 12 Oct 2011 at 10:16pm
Hi  Thank  you for the reply,  i'm new to this sorte of thing and not to good at describing things    (my daughter says its an age thing) The E is the basic model nothing fancy.
Where can I find out if it is a 114?
What is the difference and how can i tell?
 I cant se it on the reg doc.
Thanks again mate.
John...Confused
Wot bad weather?
Posted By: Taz Taylor
Date Posted: 12 Oct 2011 at 10:20pm
http://www.npoc.co.uk/forum/which-nissan-primera-do-i-own_topic194.html - http://www.npoc.co.uk/forum/which-nissan-primera-do-i-own_topic194.html
Hi and welcome. Hope this helps. It's in the general section.
Taz
Date Posted: 13 Oct 2011 at 9:23am
Thank you. Great It's a   P12. (Last but one in the pictures)
The Nissan badge is higher than the P11. pluss other things.
Now then what is the difference in the tow bolt  thread?
Once again i'm in your hands.
Thank you.
John...
Wot bad weather?
Date Posted: 16 Oct 2011 at 9:29pm
Helllooo any body in there know what is the difference?
I'm told there is a tow eye in the tool kit of new primeras
I bought mine at 1 year old with no tool kit only a jack (primeras dont break down)
I want a tow eye to pull a boat launching trailor out of the water and up the bank.
And thats it.
Does any one know?
Wot bad weather?
Posted By: riggsy99
Date Posted: 16 Oct 2011 at 9:50pm
still pretty confusing on what model you have. you say it's a P12, but its the last but one picture, which is a 144. what reg is yours? before or after 2002?
Posted By: Renegade1127
Date Posted: 17 Oct 2011 at 1:02am
I think you will find that the P11 E is the base model P11-144.
If so, it will have white clocks with the number 144 in very small lettering on the speedo.
