New member from Sirrra Leone
URL: http://www.npoc.co.uk/forum/forum_posts.asp?TID=81583
Printed Date: 23 Jul 2021 at 6:07pm
Topic: New member from Sirrra Leone
Posted By: Saffato1
Subject: New member from Sirrra Leone
Date Posted: 26 May 2021 at 3:18pm
Hello all am new with a primera P12 2003 model but presently having issues with my AC cooling system, it doesn’t cold
Posted By: roy.2
Date Posted: 26 May 2021 at 4:20pm
Hi Bob. Welcome to NPOC.  Handshake
Maybe your AC just needs a re-gas. Thumbs Up
Date Posted: 27 May 2021 at 9:19am
As Roy says as a starter, the system in addition to you blower system only has a condenser (radiator for air con) a compressor, high and low pressure pipes and the circulation gas. If you have the pressure checked it will tell you if you have gas in it, it should also tell you if it can hold pressure or there is a leak. Start from there.
